Venus rover
A project log for Silly hardware wishlist
Too simple for a project page & which may never happen.
lion-mclionheadlion mclionhead 02/20/2020 at 07:240 Comments
This video was a perfect application of
https://hackaday.io/project/162680/log/172162-the-minimal-discrete-component-computer
the minimal discrete component computer.
https://www.herox.com/VenusRover
The NASA program is specifically focused on a mechanical obstacle avoidance sensor.  The sensor communicates with the rest of the robot by moving a pin.  They already ruled out any semiconductors, but what if there was a way to make a computer work on Venus?
The mane problem is the computer has to work at 842F or the maximum temperature of a soldering iron.  The total power has come from a 1W wind turbine. Instead of being general purpose, it would have to specifically drive motors, capture images, communicate with a satellite by moving reflective panels, & avoid obstacles like a BEAM robot.
It may be a mechanical computer is the best solution.  The mechanical computer could be miniaturized down to microchip size.  Elecronics may have to run at very high voltages & large sizes.
Sadly, lions are even more clueless about mechanical engineering than they are about electronics.  Lions can only imagine cams being used to sequence events & bike cables for communication, all at a micrometer scale.
