Caliper firmware which actually goes to sleep
A project log for Silly hardware wishlist
Too simple for a project page & which may never happen.
lion-mclionheadlion mclionhead 11/05/2021 at 07:121 Comment
The lion kingdom has worked around Chinese calipers with a flaky switch for 10 years, but ideally the microprocessor would just go to sleep properly.  The switch usually glitches off & it has to be zeroed every time it's turned on.  It would require replacing the entire board, at least $50 for a gold clad board.  The calipers were only $10, in the money of the time.
Ken Yap wrote 11/05/2021 at 07:44 point
It's a pain, er pane. I just take out the cell when not in use.
