Setting up the PI and USB connection to the NexStar hand controller
A project log for Raspberry PI wireless Telescope Control
Advanced SkyFi 3 replacement for Celestron
chrisg71ChrisG71 • 12/07/2018 at 07:38•0 Comments
In the beginning I wanted to make things easy. No soldering required. As I do most observations from home I am in the range of my home Wi-Fi. The PI connects wireless to the network and power is supplied by a power adapter. Connection to the NexStar hand controller is over USB. I am using the micro-USB adapter that came with my PI Zero W  and a USB to mini -USB cable.
After finishing Instruction Step 2 you have a replacement for a SkyFi3 adapter and can control your telescope over wireless for less than $50.
