A litte bit of optimization
A project log for Raspberry PI wireless Telescope Control
Advanced SkyFi 3 replacement for Celestron
chrisg71ChrisG71 • 12/09/2018 at 14:30•0 Comments
I am adding a few instructions for optimization.
- turn off HDMI, to save a little power.
- turn off LED after we send the time to the hand controller (and location)
- change to a RO filesystem, so a hard power cut should not cause any havoc on the SD card and increase the lifetime.
I have decided to setup two boxes. One PI zero W for observing from home:
Currently I have the time set on the HC after less than 60s.
Another unit, most likely a PI 3 B+ or PI 3 A+, as the cases have a little bit more space to add the additional components. Or maybe a PI Zero in a case of a PI 3.
I dropped the idea of adding a RTC. NTP is pretty fast, and with the GPS I will have a super accurate time.
