*UPDATED* fixed a few config issues. Should work now as described.
I posted an SD-card image on DropBox: https://www.dropbox.com/s/idmsyydqbjci9l3/pi_for_telescope.dmg.zip?dl=0
You need an 16 GB (8GB might work) SD card, larger are OK as well of course.
*** UPDATE: Even I am using an 8GB to create the image it seems to be too big to write it back to an 8GB card. So please use a 16GB card. It's anyway difficult meanwhile to get an 8GB card. ***
It should boot on PI 2 B+ and PI 3 B+ and also on PI Zero W. Username: pi Password: raspberry
I finished all config steps I described in my project. But there are a few to-do's;
- Wi-Fi is NOT configured. You have to configure yourself with sudo raspi-config. For Pi 2 B+ add a USB dongle of course.
- HDMI is not turned off to allow you to boot a PI Zero with keyboard and screen so you can configure the Wi-Fi
- System is prepared for RO, but booting RW. Just change /boot/cmdline.txt
- you can add a GPS, everything is configured, just connect the hardware.
- hand controller time is set from NTP or GPS
- location is set to a fixed location, have a look at /home/pi/hc-location.sh
- Check the script to disable the green LED and run it manually /home/pi-led-off.sh You might need to change one value for your hardware.
This should give you a quick start in just 30min.
Let me know if you found the little easter egg.
ChrisG71
