astro_PI_top_v3.stl
3D printed case. Top. Has a cut for the OLED display. Depending on your OLED the pins might not work.
Printed with PLA, solid infill, supports needed.
Standard Tesselated Geometry - 285.82 kB - 12/30/2018 at 19:41
Download
astro_PI_bottom_v3.stl
3D printed case. Bottom. Pins should fit the PI. Take care of your SD card. Better remove the card before inserting or removing the PI.
Standard Tesselated Geometry - 840.02 kB - 12/30/2018 at 19:40
Download
