K9 Robot
A project to build a full size Doctor Who K-9 robot prop for my lovely wife.
A working Doctor Who K-9 Prop. It was a present for my wife which is a huge fan of the BBC show.
The robot prop uses a Raspberry Pi 3 model B and Arduino. All powered by a 12volt 10 AMP LiFePO₄ battery. It is controlled by a Futaba 8J remote and currently is only using 3 channels. The head is on a counterweight system so it can move around freely and not hurt the structure. The panels are made from fiberglass reinforced project foam board, Then covered with a layer of automotive Bondo filler and paint. I have added a detailed part list and many 3D printed files to help build your own K-9.
Current feature list:
He can speak, pseudo randomly blink the panel lights, wag his tail, and drive around
Future updates:
Would like to get some ears on him and add a laser gun to the nose.
JPEG Image - 1.11 MB - 06/14/2022 at 22:28
Preview
Download
JPEG Image - 1.93 MB - 06/14/2022 at 22:27
Preview
Download
JPEG Image - 1.30 MB - 06/14/2022 at 22:27
Preview
Download
JPEG Image - 1.03 MB - 06/14/2022 at 22:27
Preview
Download
JPEG Image - 1.05 MB - 06/14/2022 at 22:27
Preview
Download
View all 24 files
  • 1 × Arduino
  • 1 × Raspberry Pi 3
  • 2 × Super bright 5mm LED's
  • 12 × Baomain 16mm Push Button Switch Momentary Rectangular
  • 1 × 6 layer 3.3mm birch plywood For base and electronics holder
View all 29 components
  • Boosted Audio before Comic-Con
    Apollo Timbers06/14/2022 at 22:25 0 comments
    Added audio that runs on internal battery. Bought a speaker and amp from Amazon and installed in the robot, seems to produce much louder sound which is nice though I'm hearing a lot of feedback/noise. Probably going to add a copper shield around to reduce interference. (Likely caused by the motors or background noise). In this implementation a hole was cut out of the base for the sound to travel out of the robot without it sounding muffled. This was added as in previous times it was difficult to hear the self contained "Jawbone mini"  that was used before.
  • 3D printed metal ears
    Apollo Timbers11/20/2021 at 17:07 0 comments
    Added a photo of K-9 with the 3D printed metal ears.
View all 2 project logs
  • 1
    Powering 12 volt panel LED's with a Arduino using a transistor bank
    You cannot directly drive 12V LEDs from a Arduino. I used 2 ULN2003 ICs I wired up the Arduino to pseudo random blink the Baomain 16mm push button momentary switches.
    Here is a good representation of the circuit in GIF format. You do not need a resistor before the LEDs as they have one built in. I then heavily modified the "A clean sweep" program credit to Adafruit. Mostly adding additional LED channels and randomness in the timings. Here is a link to their awesome tutorial for Arduino multitasking. (Link)
View all instructions
Apollo Timbers wrote 07/16/2022 at 16:57 point
Thank you, and yes I should upload a video or two. I put a lot of effort in the build and it too at least to me, is close to a real movie prop as you can prob get. We recently took it to a local comic-con and K-9 was a big hit. He never missed a beat and we could barely go anywhere as we were stopped often for a photoshoot. Though that was the fun of it, to make other happy to see it.
Stephen Moody wrote 06/16/2022 at 16:37 point
As a Doctor Who fan myself, especially some of the earlier series I have to say this is a fantastic build. If you haven't already I would suggest take a couple of videos of K9 in action
