Osmar
Open Source Microsyringe Autosampler - bit.ly/2QVnDJU
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Full descriptioni at bit.ly/2QVnDJU Microsyringe manipulation is a common approach for the automated sampling of liquids or gases. Commercial devices with this capacity are typically priced above US$30,000, despite their technology being not clearly superior to that commonly found in low-cost (commonly less than US$1,000) devices controlled using G-code (3D printers, CNC routers and laser engravers, for example). Here, we present osmar, an open-source autosampler built by combining parts of two low-cost G-code machines. Movement precision was excellent (error < 1% in repeated injections, equivalent to the error reported by the microsyringe manufacturer), and system reliability was comparable to that of commercial models. Also, users do not need extensive knowledge in electronics or advanced computing to make osmar work as an autosampler, because it can easily be integrated with analytical instrumen
