Attaching the stepper motor to the paddle
A project log for Hedgehog Feeder
Hedgehogs in the UK are classed as an endangered species. For this reason I have chosen my final year project to be a hedgehog feeder.
abigail-smithAbigail Smith 02/26/2019 at 19:080 Comments
So today, i spent the day attaching the stepping motor to the paddle in the cereal dispenser in the University of Sheffield’s makerspace, otherwise known as the iForge.
First, I used a laser cutter to cut two 70mm diameter circle from some scrap wood. Using a pillar drill, I drilled four 4.8mm holes into each of the circlular wood pieces. One more hole was drilled in the centre of one piece of circular wood for the stepper motor to be inserted into.
Using hot glue, I then attached the handle that I had hacksawed the day before and let it set.
The two circular pieces of wood were then bolted together back to back.
