Divide and Conquer Wins
A project log for SCARA Controller
A Controller for a SCARA Arm
agp.cooperagp.cooper 12/11/2018 at 12:440 Comments
Divide and Conquer (Option 1)
After playing with the Options presented in my first post, I have decided Option 1 is the best. Why? It  should have the least number of the expensive reverse kinematic calculations. Consider a very coarse tolerance (=128):
Note that the UV space (blue lines) has only 6 points (the straight lines between them are Bressenham lines).
Now the medium tolerance case (=32):
Here there is only 13 reverse kinematic calculations.
Now the very fine tolerance (=8):
Here there is only 25 reverse kinematic calculations.
Finally ultra fine tolerance (=1), has 67 calculations:
Fast Trigonometry
Although the number of reverse kinematic calculations are a minimum, there still may be advantage is fast (integer?) methods. The CORDIC algorithm comes to mind, especially for the ATAN2() and sqrt() functions. ArcSin/ArcCos should also be possible.
Here is my version of Rect2Polar (i.e ATAN2() and sqrt()) using short (i.e int16) integers:
// Include libraries
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <string.h>
#include <math.h>
#include <stdbool.h>
void rect2polar(short X,short Y,short *R,short *A)
  // ATAN_Table is the values of ATAN(1/(2^i))*400*32/2/Pi micro-steps
  short ATAN[12]={1600,945,499,253,127,64,32,16,8,4,2,1};
  short i,Xnew,Ynew;
  (*A)=0;
  if (X<0) {
    (*A)=200*32; // 180 degrees
    X=-X;
    Y=-Y;
  } else if (Y<0) {
    (*A)=400*32; // =360 degrees
  for (i=0;i<12;i++) {
    if (Y<0) {
      // Rotate CCW
      Xnew=X-(Y>>i);
      Ynew=Y+(X>>i);
      (*A)=(*A)-ATAN[i];
    } else {
      // Rotate CW
      Xnew=X+(Y>>i);
      Ynew=Y-(X>>i);
      (*A)=(*A)+ATAN[i];
    X=Xnew;
    Y=Ynew;
  // Adjust for gain (=X*0.607252935)
  X=X>>1;
  (*R)=(((((((((((((((((X>>2)+X)>>2)+X)>>1)+X)>>1)+X)>>2)+X)>>1)+X)>>2)+X)>>1)+X)>>3)+X;
int main(void) {
  short A,R,X,Y;
  X=-439*32;
  Y=-439*32;
  // R=621*32 max
  rect2polar(X,Y,&R,&A);
  printf("Rect2Polar x %8.3f y %8.3f ang %8.3f hyp %8.3f\n",X/32.0,Y/32.0,A*360.0/400.0/32.0,R/32.0);
  printf("atan2()    x %8.3f y %8.3f ang %8.3f hyp %8.3f\n",X/32.0,Y/32.0,360+atan2(Y,X)*180/M_PI,sqrt(X*X+Y*Y)/32.0);
  return 0;
Here is the result:
$ ./ShortCAtan
Rect2Polar x -439.000 y -439.000 ang  225.028 hyp  620.812
atan2()        x -439.000 y -439.000 ang  225.000 hyp  620.840
So about  4 digits of accuracy with 16 bit integers.
Reverse Kinematica
I reworked the mathematics to suit CORDIC:
ArcSin CORDIC
Here is my ArcSin CORDIC:
// This version works properly but has a multiplication in the main loop
short arcSin(short R, short S) {
  // SEC[i]=(int)((1/COS(ATAN(1/(2^i)))-1)*(2>>14)+0.5);
  short SEC[15]={6787,1935,505,128,32,8,2,1,1,1,1,1,1,1,1};
  short i,Rnew,Y,Ynew,A;
  Y=0;
  A=0;
  for (i=0;i<=11;i++) {
    if ((Y<S)&&(A<100*32)) { // 90 degrees
      // Rotate CCW
      Ynew=Y+(R>>i);
      Rnew=R-(Y>>i);
      A=A+ATAN[i];
    } else {
      // Rotate CW
      Ynew=Y-(R>>i);
      Rnew=R+(Y>>i);
      A=A-ATAN[i];
    Y=Ynew;
    R=Rnew;
    S=S+((S*SEC[i])>>14);
  return A;
 The down side of my ArcSin CORDIC is the multiplication inside the main loop. I remember I had to do the multiplication to avoid instability.
AlanX
