Prototype Hardware
A project log for SCARA Controller
A Controller for a SCARA Arm
agp.cooperagp.cooper 02/04/2019 at 04:381 Comment
Very Simple Hardware
A simple laser SCARA:
It uses 50mmx25mmx3mm aluminum bracket.
The main downsides are:
Still it should be useful for testing.
Reworked the design
Reworked the design away from 50mm x 25mm 3mm aluminum angle.
Here is a 6mm MDF design:
And the laser cutout (300mmx300mmx6mm MDF sheet):
The bending moment calculations suggest less than 0.5mm deflection (assumes 2.5N end load). Maximum end load is 30N (~5mm deflection).
I sent the design away to be cut by a professional laser cutting company.
AlanX
Pete Prodoehl wrote 9 hours ago point
I'd be willing to cut and assemble one of these if you want to share the vector file.
