In late 2018 while studying at Monash University, I started a project for the unit "FIT3146 - Emergent Technologies". This was a "physical programming language" using Arduinos as programming blocks. The proof of concept was a success, so now I am documenting what I did with the aim of taking this idea further...
The Tangible Programming project is a new way of teaching programming. Instead of learning to program by typing code, or by using drag and drop (a la Scratch), Tangible Programming is designed to be a tactile programming experience. Using physical modules which you plug together, you create a program just like building with Lego. By plugging the brightly coloured modules into each other you build up your program. The main control unit will show you which blocks are attached and when the entire program is connected and read in you can follow the progress as it executes as each module lights up as it is being executed.
While the current prototype only offers a few commands, more programming commands are planned, including support for strings, functions and even integration with Arduino sensors and modules.
I have just barely got my feet wet with my Arduino 328 controlled 4x4x4 led cube so I hope to learn a bit more from all this :-)
