Results of Training the Customised Network
12/12/2018 at 13:57 • 0 commentsI trained my first customised network, as designed in the previous log, on an Amazon AWS GPU and successfully got convergence, which means the network does work:
Baby steps
12/11/2018 at 16:15 • 0 commentsAfter messing about with some networks for a couple of months in an attemt to design computer vision for machines, I started to notice a few re-occurring topics and buzz words such as 'prototext' and 'weights'.
Curiosity has now got the better of me and I worked out that the various prototext files associated with a network describe it's structure in reasonably simple and human readable terms eg:
layer { name: "pool2/3x3_s2" type: "Pooling" bottom: "conv2/norm2" top: "pool2/3x3_s2" pooling_param { pool: MAX kernel_size: 3 stride: 2 } }
I presume that this is a python layer, but I'm not sure, but it does not matter for now.
The fantastic Nvidia Digits software enables print out of a fancy graphical representation of the whole network and, starting with the renowned bvlc_googlenet.caffemodel, I thought I'd try and hack it and learn something through experimentation.
One of the first thing I looked for was symmetry and repetition, with the desire to simplify what initially look very complicated. I noticed that the above layer describes a 'link' between other blocks of layers that seem to repeat themselves about 6 times:
...... in the massive bvlc_googlenet network:
..... and in this way I managed to simplify it by removing what looked like about 6 large blocks of repeating layers to this:
...... And looking at this diagram very carefully, there's still one big block that repeats and should also be able to be removed. I tried removing it, but unfortunately gave this error:
Creating layer coverage/sig Creating Layer coverage/sig coverage/sig <- cvg/classifier coverage/sig -> coverage Setting up coverage/sig Top shape: 2 1 80 80 (12800) Memory required for data: 851282688 Creating layer bbox/regressor Creating Layer bbox/regressor bbox/regressor <- pool5/drop_s1_pool5/drop_s1_0_split_1 bbox/regressor -> bboxes Setting up bbox/regressor Top shape: 2 4 80 80 (51200) Memory required for data: 851487488 Creating layer bbox_mask Creating Layer bbox_mask bbox_mask <- bboxes bbox_mask <- coverage-block bbox_mask -> bboxes-masked Check failed: bottom[i]->shape() == bottom[0]->shape()
...... So that's it for now ..... and here's my 'simplified' network prototext for object detection:
# DetectNet network
# DetectNet network # Data/Input layers name: "DetectNet" layer { name: "train_data" type: "Data" top: "data" data_param { backend: LMDB source: "examples/kitti/kitti_train_images.lmdb" batch_size: 10 } include: { phase: TRAIN } } layer { name: "train_label" type: "Data" top: "label" data_param { backend: LMDB source: "examples/kitti/kitti_train_labels.lmdb" batch_size: 10 } include: { phase: TRAIN } } layer { name: "val_data" type: "Data" top: "data" data_param { backend: LMDB source: "examples/kitti/kitti_test_images.lmdb" batch_size: 6 } include: { phase: TEST stage: "val" } } layer { name: "val_label" type: "Data" top: "label" data_param { backend: LMDB source: "examples/kitti/kitti_test_labels.lmdb" batch_size: 6 } include: { phase: TEST stage: "val" } } layer { name: "deploy_data" type: "Input" top: "data" input_param { shape { dim: 1 dim: 3 dim: 640 dim: 640 } } include: { phase: TEST not_stage: "val" } } # Data transformation layers layer { name: "train_transform" type: "DetectNetTransformation" bottom: "data" bottom: "label" top: "transformed_data" top: "transformed_label" detectnet_groundtruth_param: { stride: 16 scale_cvg: 0.4 gridbox_type: GRIDBOX_MIN coverage_type: RECTANGULAR min_cvg_len: 20 obj_norm: true image_size_x: 640 image_size_y: 640 crop_bboxes: false object_class: { src: 1 dst: 0} # obj class 1 -> cvg index 0 } detectnet_augmentation_param: { crop_prob: 1 shift_x: 32 shift_y: 32 flip_prob: 0.5 rotation_prob: 0 max_rotate_degree: 5 scale_prob: 0.4 scale_min: 0.8 scale_max: 1.2 hue_rotation_prob: 0.8 hue_rotation: 30 desaturation_prob: 0.8 desaturation_max: 0.8 } transform_param: { mean_value: 127 } include: { phase: TRAIN } } layer { name: "val_transform" type: "DetectNetTransformation" bottom: "data" bottom: "label" top: "transformed_data" top: "transformed_label" detectnet_groundtruth_param: { stride: 16 scale_cvg: 0.4 gridbox_type: GRIDBOX_MIN coverage_type: RECTANGULAR min_cvg_len: 20 obj_norm: true image_size_x: 640 image_size_y: 640 crop_bboxes: false object_class: { src: 1 dst: 0} # obj class 1 -> cvg index 0 } transform_param: { mean_value: 127 } include: { phase: TEST stage: "val" } } layer { name: "deploy_transform" type: "Power" bottom: "data" top: "transformed_data" power_param { shift: -127 } include: { phase: TEST not_stage: "val" } } # Label conversion layers layer { name: "slice-label" type: "Slice" bottom: "transformed_label" top: "foreground-label" top: "bbox-label" top: "size-label" top: "obj-label" top: "coverage-label" slice_param { slice_dim: 1 slice_point: 1 slice_point: 5 slice_point: 7 slice_point: 8 } include { phase: TRAIN } include { phase: TEST stage: "val" } } layer { name: "coverage-block" type: "Concat" bottom: "foreground-label" bottom: "foreground-label" bottom: "foreground-label" bottom: "foreground-label" top: "coverage-block" concat_param { concat_dim: 1 } include { phase: TRAIN } include { phase: TEST stage: "val" } } layer { name: "size-block" type: "Concat" bottom: "size-label" bottom: "size-label" top: "size-block" concat_param { concat_dim: 1 } include { phase: TRAIN } include { phase: TEST stage: "val" } } layer { name: "obj-block" type: "Concat" bottom: "obj-label" bottom: "obj-label" bottom: "obj-label" bottom: "obj-label" top: "obj-block" concat_param { concat_dim: 1 } include { phase: TRAIN } include { phase: TEST stage: "val" } } layer { name: "bb-label-norm" type: "Eltwise" bottom: "bbox-label" bottom: "size-block" top: "bbox-label-norm" eltwise_param { operation: PROD } include { phase: TRAIN } include { phase: TEST stage: "val" } } layer { name: "bb-obj-norm" type: "Eltwise" bottom: "bbox-label-norm" bottom: "obj-block" top: "bbox-obj-label-norm" eltwise_param { operation: PROD } include { phase: TRAIN } include { phase: TEST stage: "val" } } ###################################################################### # Start of convolutional network ###################################################################### layer { name: "conv1/7x7_s2" type: "Convolution" bottom: "transformed_data" top: "conv1/7x7_s2" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 64 pad: 3 kernel_size: 7 stride: 2 weight_filler { type: "xavier" std: 0.1 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "conv1/relu_7x7" type: "ReLU" bottom: "conv1/7x7_s2" top: "conv1/7x7_s2" } layer { name: "pool1/3x3_s2" type: "Pooling" bottom: "conv1/7x7_s2" top: "pool1/3x3_s2" pooling_param { pool: MAX kernel_size: 3 stride: 2 } } layer { name: "pool1/norm1" type: "LRN" bottom: "pool1/3x3_s2" top: "pool1/norm1" lrn_param { local_size: 5 alpha: 0.0001 beta: 0.75 } } layer { name: "conv2/3x3_reduce" type: "Convolution" bottom: "pool1/norm1" top: "conv2/3x3_reduce" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 64 kernel_size: 1 weight_filler { type: "xavier" std: 0.1 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "conv2/relu_3x3_reduce" type: "ReLU" bottom: "conv2/3x3_reduce" top: "conv2/3x3_reduce" } layer { name: "conv2/3x3" type: "Convolution" bottom: "conv2/3x3_reduce" top: "conv2/3x3" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 192 pad: 1 kernel_size: 3 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "conv2/relu_3x3" type: "ReLU" bottom: "conv2/3x3" top: "conv2/3x3" } layer { name: "conv2/norm2" type: "LRN" bottom: "conv2/3x3" top: "conv2/norm2" lrn_param { local_size: 5 alpha: 0.0001 beta: 0.75 } } layer { name: "pool2/3x3_s2" type: "Pooling" bottom: "conv2/norm2" top: "pool2/3x3_s2" pooling_param { pool: MAX kernel_size: 3 stride: 2 } } ########################################################### 3a starts layer { name: "inception_3a/1x1" type: "Convolution" bottom: "pool2/3x3_s2" top: "inception_3a/1x1" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 64 kernel_size: 1 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_3a/relu_1x1" type: "ReLU" bottom: "inception_3a/1x1" top: "inception_3a/1x1" } layer { name: "inception_3a/3x3_reduce" type: "Convolution" bottom: "pool2/3x3_s2" top: "inception_3a/3x3_reduce" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 96 kernel_size: 1 weight_filler { type: "xavier" std: 0.09 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_3a/relu_3x3_reduce" type: "ReLU" bottom: "inception_3a/3x3_reduce" top: "inception_3a/3x3_reduce" } layer { name: "inception_3a/3x3" type: "Convolution" bottom: "inception_3a/3x3_reduce" top: "inception_3a/3x3" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 128 pad: 1 kernel_size: 3 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_3a/relu_3x3" type: "ReLU" bottom: "inception_3a/3x3" top: "inception_3a/3x3" } layer { name: "inception_3a/5x5_reduce" type: "Convolution" bottom: "pool2/3x3_s2" top: "inception_3a/5x5_reduce" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 16 kernel_size: 1 weight_filler { type: "xavier" std: 0.2 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_3a/relu_5x5_reduce" type: "ReLU" bottom: "inception_3a/5x5_reduce" top: "inception_3a/5x5_reduce" } layer { name: "inception_3a/5x5" type: "Convolution" bottom: "inception_3a/5x5_reduce" top: "inception_3a/5x5" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 32 pad: 2 kernel_size: 5 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_3a/relu_5x5" type: "ReLU" bottom: "inception_3a/5x5" top: "inception_3a/5x5" } layer { name: "inception_3a/pool" type: "Pooling" bottom: "pool2/3x3_s2" top: "inception_3a/pool" pooling_param { pool: MAX kernel_size: 3 stride: 1 pad: 1 } } layer { name: "inception_3a/pool_proj" type: "Convolution" bottom: "inception_3a/pool" top: "inception_3a/pool_proj" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 32 kernel_size: 1 weight_filler { type: "xavier" std: 0.1 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_3a/relu_pool_proj" type: "ReLU" bottom: "inception_3a/pool_proj" top: "inception_3a/pool_proj" } ################################################################### start of connecting block layer { name: "inception_3a/output" type: "Concat" bottom: "inception_3a/1x1" bottom: "inception_3a/3x3" bottom: "inception_3a/5x5" bottom: "inception_3a/pool_proj" top: "inception_3a/output" } ################################################################### 3a finish ################################################################### start of connecting block layer { name: "pool3/3x3_s2" type: "Pooling" bottom: "inception_3a/output" top: "pool3/3x3_s2" pooling_param { pool: MAX kernel_size: 3 stride: 2 } } ################################################################### 4a starts layer { name: "inception_4a/1x1" type: "Convolution" bottom: "pool3/3x3_s2" top: "inception_4a/1x1" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 192 kernel_size: 1 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_4a/relu_1x1" type: "ReLU" bottom: "inception_4a/1x1" top: "inception_4a/1x1" } layer { name: "inception_4a/3x3_reduce" type: "Convolution" bottom: "pool3/3x3_s2" top: "inception_4a/3x3_reduce" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 96 kernel_size: 1 weight_filler { type: "xavier" std: 0.09 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_4a/relu_3x3_reduce" type: "ReLU" bottom: "inception_4a/3x3_reduce" top: "inception_4a/3x3_reduce" } layer { name: "inception_4a/3x3" type: "Convolution" bottom: "inception_4a/3x3_reduce" top: "inception_4a/3x3" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 208 pad: 1 kernel_size: 3 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_4a/relu_3x3" type: "ReLU" bottom: "inception_4a/3x3" top: "inception_4a/3x3" } layer { name: "inception_4a/5x5_reduce" type: "Convolution" bottom: "pool3/3x3_s2" top: "inception_4a/5x5_reduce" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 16 kernel_size: 1 weight_filler { type: "xavier" std: 0.2 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_4a/relu_5x5_reduce" type: "ReLU" bottom: "inception_4a/5x5_reduce" top: "inception_4a/5x5_reduce" } layer { name: "inception_4a/5x5" type: "Convolution" bottom: "inception_4a/5x5_reduce" top: "inception_4a/5x5" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 48 pad: 2 kernel_size: 5 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_4a/relu_5x5" type: "ReLU" bottom: "inception_4a/5x5" top: "inception_4a/5x5" } layer { name: "inception_4a/pool" type: "Pooling" bottom: "pool3/3x3_s2" top: "inception_4a/pool" pooling_param { pool: MAX kernel_size: 3 stride: 1 pad: 1 } } layer { name: "inception_4a/pool_proj" type: "Convolution" bottom: "inception_4a/pool" top: "inception_4a/pool_proj" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 64 kernel_size: 1 weight_filler { type: "xavier" std: 0.1 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_4a/relu_pool_proj" type: "ReLU" bottom: "inception_4a/pool_proj" top: "inception_4a/pool_proj" } ################################################################### 4a finish layer { name: "inception_4a/output" type: "Concat" bottom: "inception_4a/1x1" bottom: "inception_4a/3x3" bottom: "inception_4a/5x5" bottom: "inception_4a/pool_proj" top: "inception_4a/output" } ################################################################### start of connecting block layer { name: "inception_5a/1x1" type: "Convolution" bottom: "inception_4a/output" top: "inception_5a/1x1" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 256 kernel_size: 1 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_5a/relu_1x1" type: "ReLU" bottom: "inception_5a/1x1" top: "inception_5a/1x1" } layer { name: "inception_5a/3x3_reduce" type: "Convolution" bottom: "inception_4a/output" top: "inception_5a/3x3_reduce" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 160 kernel_size: 1 weight_filler { type: "xavier" std: 0.09 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_5a/relu_3x3_reduce" type: "ReLU" bottom: "inception_5a/3x3_reduce" top: "inception_5a/3x3_reduce" } layer { name: "inception_5a/3x3" type: "Convolution" bottom: "inception_5a/3x3_reduce" top: "inception_5a/3x3" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 320 pad: 1 kernel_size: 3 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_5a/relu_3x3" type: "ReLU" bottom: "inception_5a/3x3" top: "inception_5a/3x3" } layer { name: "inception_5a/5x5_reduce" type: "Convolution" bottom: "inception_4a/output" top: "inception_5a/5x5_reduce" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 32 kernel_size: 1 weight_filler { type: "xavier" std: 0.2 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_5a/relu_5x5_reduce" type: "ReLU" bottom: "inception_5a/5x5_reduce" top: "inception_5a/5x5_reduce" } layer { name: "inception_5a/5x5" type: "Convolution" bottom: "inception_5a/5x5_reduce" top: "inception_5a/5x5" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 128 pad: 2 kernel_size: 5 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_5a/relu_5x5" type: "ReLU" bottom: "inception_5a/5x5" top: "inception_5a/5x5" } layer { name: "inception_5a/pool" type: "Pooling" bottom: "inception_4a/output" top: "inception_5a/pool" pooling_param { pool: MAX kernel_size: 3 stride: 1 pad: 1 } } layer { name: "inception_5a/pool_proj" type: "Convolution" bottom: "inception_5a/pool" top: "inception_5a/pool_proj" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 128 kernel_size: 1 weight_filler { type: "xavier" std: 0.1 } bias_filler { type: "constant" value: 0.2 } } } layer { name: "inception_5a/relu_pool_proj" type: "ReLU" bottom: "inception_5a/pool_proj" top: "inception_5a/pool_proj" } ################################################################### start of connecting block layer { name: "inception_5a/output" type: "Concat" bottom: "inception_5a/1x1" bottom: "inception_5a/3x3" bottom: "inception_5a/5x5" bottom: "inception_5a/pool_proj" top: "inception_5a/output" } ################################################################### start of connecting block layer { name: "pool5/drop_s1" type: "Dropout" bottom: "inception_5a/output" top: "pool5/drop_s1" dropout_param { dropout_ratio: 0.4 } } layer { name: "cvg/classifier" type: "Convolution" bottom: "pool5/drop_s1" top: "cvg/classifier" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 1 kernel_size: 1 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0. } } } layer { name: "coverage/sig" type: "Sigmoid" bottom: "cvg/classifier" top: "coverage" } layer { name: "bbox/regressor" type: "Convolution" bottom: "pool5/drop_s1" top: "bboxes" param { lr_mult: 1 decay_mult: 1 } param { lr_mult: 2 decay_mult: 0 } convolution_param { num_output: 4 kernel_size: 1 weight_filler { type: "xavier" std: 0.03 } bias_filler { type: "constant" value: 0. } } } ###################################################################### # End of convolutional network ###################################################################### # Convert bboxes layer { name: "bbox_mask" type: "Eltwise" bottom: "bboxes" bottom: "coverage-block" top: "bboxes-masked" eltwise_param { operation: PROD } include { phase: TRAIN } include { phase: TEST stage: "val" } } layer { name: "bbox-norm" type: "Eltwise" bottom: "bboxes-masked" bottom: "size-block" top: "bboxes-masked-norm" eltwise_param { operation: PROD } include { phase: TRAIN } include { phase: TEST stage: "val" } } layer { name: "bbox-obj-norm" type: "Eltwise" bottom: "bboxes-masked-norm" bottom: "obj-block" top: "bboxes-obj-masked-norm" eltwise_param { operation: PROD } include { phase: TRAIN } include { phase: TEST stage: "val" } } # Loss layers layer { name: "bbox_loss" type: "L1Loss" bottom: "bboxes-obj-masked-norm" bottom: "bbox-obj-label-norm" top: "loss_bbox" loss_weight: 2 include { phase: TRAIN } include { phase: TEST stage: "val" } } layer { name: "coverage_loss" type: "EuclideanLoss" bottom: "coverage" bottom: "coverage-label" top: "loss_coverage" include { phase: TRAIN } include { phase: TEST stage: "val" } } # Cluster bboxes layer { type: 'Python' name: 'cluster' bottom: 'coverage' bottom: 'bboxes' top: 'bbox-list' python_param { module: 'caffe.layers.detectnet.clustering' layer: 'ClusterDetections' param_str : '640, 640, 16, 0.6, 2, 0.02, 22, 1' } include: { phase: TEST } } # Calculate mean average precision layer { type: 'Python' name: 'cluster_gt' bottom: 'coverage-label' bottom: 'bbox-label' top: 'bbox-list-label' python_param { module: 'caffe.layers.detectnet.clustering' layer: 'ClusterGroundtruth' param_str : '640, 640, 16, 1' } include: { phase: TEST stage: "val" } } layer { type: 'Python' name: 'score' bottom: 'bbox-list-label' bottom: 'bbox-list' top: 'bbox-list-scored' python_param { module: 'caffe.layers.detectnet.mean_ap' layer: 'ScoreDetections' } include: { phase: TEST stage: "val" } } layer { type: 'Python' name: 'mAP' bottom: 'bbox-list-scored' top: 'mAP' top: 'precision' top: 'recall' python_param { module: 'caffe.layers.detectnet.mean_ap' layer: 'mAP' param_str : '640, 640, 16' } include: { phase: TEST stage: "val" } }
I'll have to have a go at training a model with this network on my wasp images.
