More fitting work, soldering up headers.
Stack from bottom to top:
- Adafruit Feather M0 Express
- Adafruit Latching Relay wing, Raspberry Pi Zero W
- Adafruit Raspberry Pi Protosheild (I didn't do enough research on this - it's the older 26 pin header not the current 40 pin - fortunately the pHat I'm using works fine with only 26 pins)
- Pomironi eInk pHat and power cutoff relay for Feather stack and SSD1327 OLED display and rotary encoder
Not on the stack:
- Neopixel stick
- Mcp9808 for feather
- Bme680 for pi
- Usb case connector
