Hackaday.io Hackaday.io
Sign up Log in
ESP32 Development Board
ESP32 Module with A CP2102 http://www.analoglamb.com/product/esp32-development-board/
abrahamAbraham
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.8k views
7 comments
20 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 2
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 7
View Gallery
3.8k
7
20
14
Team (1)
  • abrahamAbraham
Join this project's team
  • Buy on Tindie
  • Buy on AnalogLamb
  • Schematics
  • Follow Us - Twitter
hardware
completed project
ESP32 ESP8266 ESP3212 esp-32s EPS-WROOM32 Espressif
Related lists
Awesome Projects on Tindie
Hackaday.io projects you can buy in the Tindie maker marketplace
ESP32 Projects
All about ESP32 Projects
Macro pads
List of macro pads for ideas
This project is submitted for
  • Hackaday.com Tip Line
  • Enlightened Raspberry Pi
  • The 1kB Challenge
This project was created on 10/12/2016 and last updated 8 years ago.
Description
ESP32 Development Board is for developers. And It provides a USB to USART Chip CP2102. Developers can use CP2102 to program and debug ESP32.
The ESP8266 started a small revolution by bringing WiFi to a small and cheap package that also had enough processing power and enough pins to get small things done. Now get ready to take your bite-sized WiFi capabilities to the next level with the ESP32 Development Board!
The development board breaks out all the module’s pins to 0.1″ headers and provides a CP2102 USB-TTL serial adapter, programming and reset buttons, and a power regulator to supply the ESP32 with a stable 3.3 V. Espressif doubled-down on the CPU resources for the ESP32 with a dual core, running at 160MHz and tons more pins and peripherals.
Features
Use ESP-32S, ESP-WROOM32 or ESP-32S-ALB Module
USB to UART CP2102 Chip
LDO output current about 800mA
Supports Auto download circuit
2 x Buttons for Reset and Boot
All ESP32 GPIO pins Available
Files
AnalogLamb__ESP32 Development Board_V2_SCH.pdf
Adobe Portable Document Format - 21.58 kB - 01/10/2017 at 05:50
Preview
Components
  • 1 × ESP32 WiFi & Bluetooth combo Chip
  • 1 × CP2102 USB to USART chip for Programming and Debugging.
Project Logs
Collapse
  • ESP32 Development Board can buy it on Tindie & AnalogLamb
    Abraham • 01/10/2017 at 06:04 • 0 comments
    Buy it Tindie: https://www.tindie.com/products/analoglamb/esp32-development-board-with-cp2102-usb-to-uart/
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Rui Rex wrote 10/20/2016 at 14:18 • point
Seriously??? You're just using this to promote your sales?!?!!? Get real...
Abraham wrote 01/05/2017 at 07:38 • point
Sorry, too busy. But I will upload schematics later. Thanks
Abraham wrote 01/10/2017 at 06:06 • point
Hi, Sorry for late. But you can download schematic now. Thanks
AVR wrote 10/18/2016 at 20:35 • point
schematic ?
Abraham wrote 01/10/2017 at 06:05 • point
Mini ESP32 development board
Project Owner Contributor
ESPea32
yancanyancan
convert esp32 into a plug-able mini-module.
esp32-socket
christoph-tackChristoph Tack
The 2018 Hackaday Prize
Unhappy with the ESP32-WROOM module, I designed an ESP32 D2WD module to ease custom board assembly and enable small, wearable ESP32 devices
Small ESP32 Module for Easier Custom Design
kris-winerKris Winer
Quick-to-use ESP32 development device
ESP32-USB-stick
turo-heikkinenTuro Heikkinen
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "ESP32 Development Board", please tell us the reason.
Send message
Remove Member
