BMS current consumption
A project log for JBD BMS Arduino library
In this project, I collect any information about BMS that is compatible with the JBDTool program.
alexanderAlexander 06/11/2019 at 11:520 Comments
I measured the currents of the consumption of the BMS itself.
The results are below.
ModeCurrent consumption
The load is not connected, the LED on the board is not on.70 uA, and every five seconds 150..200 uA
The load is not connected, the LED on the board is not on, BMS connected to PC through UART100 uA, and every five seconds 200 uA
LED on the board is on18 mA
