35mm Film Bracket.f3dFusion 360 model containing both halves of the film gate/clamp and the mount for my light source.f3d - 606.35 kB - 12/17/2018 at 02:55 |
Lower gate.stlBottom half of the film gate/clampStandard Tesselated Geometry - 201.25 kB - 12/17/2018 at 02:55 |
Upper gate.stlTop half of the film gate/clampStandard Tesselated Geometry - 132.31 kB - 12/17/2018 at 02:55 |
Bracket.stlAdapter for the specific down-light I used. You'll probably want to create a custom mount to use for your specific light source.Standard Tesselated Geometry - 888.66 kB - 12/17/2018 at 02:55 |
Light holder.f3dFusion 360 model for the down-light case. Unless you're using the same light, this probably isn't useful.f3d - 85.09 kB - 12/18/2018 at 03:31 |
light-holder.stlCase for the specific down-light I used. Unless you're using the same light, this probably isn't useful.Standard Tesselated Geometry - 103.89 kB - 12/18/2018 at 03:31 |
_MG_9631-full.jpgFull resolution example scan: Smudge the cat (2002, Kodak Gold 100 ISO)JPEG Image - 10.30 MB - 12/21/2018 at 08:46 |
_MG_9631-full-NLP.jpgFull resolution example scan, processed using the Negative Lab Pro Lightroom plugin (2002, Kodak Gold 100 ISO)JPEG Image - 11.14 MB - 02/13/2019 at 07:43 |
_MG_1940-full.jpgFull resolution example scan: Olly the cat (1996, Kodak Gold 200 ISO)JPEG Image - 8.12 MB - 12/18/2018 at 21:12 |
WPS-15-dollar-scan.JPGFull resolution "Super High Quality" scan from Wellington Photographic SuppliesJPEG Image - 5.77 MB - 01/11/2019 at 05:47 |
PhotoWarehouse-5-dollar-scan.JPGFull resolution "High Resolution" scan from Wellington Photo WarehouseJPEG Image - 8.66 MB - 01/18/2019 at 23:14 |
