Troubleshooting Attempts (Link to videos in text)
A project log for "Straddle Crane" Self-Balancing Robot
I am aiming to create a new self-balancing robot that can drive around an object, pick it up, carry it and offload it.
ben-petersBen Peters 02/28/2019 at 11:480 Comments
Prior to this testing the robot perfromcance can be summarised: robot could balance for a maximum of about 20 seconds but was very inconsitent, the robot ususally failed because it started to rotate (nothing in the code was telling it to rotate), sometimes the robot would stay at top dead centre then just appear to give up; ie it was not just an issue of a poorly tuned PID controller, there was some undesired behaviour occuring. The code conducted a calibration sequence whilst supporting the robot vertically and would just start trying to balance once the callibration sequence was complete.
Conducted a few hours of testing and adjusting in an attempt to get the robot balancing. I tested in the iForge makerspace using a string harness (to stop the robot falling over) and logging some of the values to the sensor and control values to the serial monitor. Summary follows:
Please see a selection of the testing videos using this link, notably showing the robot rotating then failing.
