Lion FPGA CPU/Computer
A 16-bit FPGA CPU I call Lion CPU and a computer, the Lion computer. Everything built from scratch.
I started to explore FPGAs and made a CPU, then when I realized that it really works I set a goal to make a computer like the 80's home computers I used as a kid and I think I did it.
I built a video controller, a UART, wrote an assembler and ported PA Tiny Basic adding fixed point and more. It started to feel like a home computer. I added SPI to use a SD Card and wrote simple FAT system support. For sound I made two audio channels and a noise channel.
Then I added hardware sprites.
I made a generator for Lion CPU code for the Java Grinder open source project and so I have a simple Java Compiler for Lion. Then I wrote a simple demo game in Java. Of course I have added joystick port.
I added a second video mode 16 colors and 45 multi-color sprites.
Last addition is Cpu support for 8 pages of 64K (512K total).
Manos wrote a nice windows emulator of Lion in C#.
Still more to do in hardware and software but it already is a working computer.
Leon (Theodoulos Liontakis)
Current Specs
CPU : Lion 16bit  @50Mhz
Memory:  8K rom + 56K ram + 32K video ram + 12K sprites ram + 64K paged ram
                support for up to 512K total ram in 64K pages.
Video Mode 0  (text optimized):  640x240 pixels, 30x80 chars, 16 colors (2 per char)
Video Mode 1  (graphics optimized):  320x200 pixels, 25x53 chars, 16 colors
Sprites: 45 colorful 16x16 pixels hardware sprites, double buffered.
Storage: basic FAT support in SD card 30Mbytes
Sound: 2 channels + 1 noise channel
Ports:   2x joystick, 1x Serial, 1x VGA, 1x PS/2 keyboard (works as serial)
Software: Assembler, Palo Alto Tiny Basic (with fixed point arithmetic),
                 Java Grinder Compiler (with floating point support), Astro java game.
And a Lion Windows emulator written by Manos in C# see github project link.
Source code availiable at github (CPU+system VHDL/schematic, assembler, Rom+TBasic assembly)
More information and assembly description at my website (first project page).
  • 1 × Cyclone IV EP4CE15 board
  • 1 × AS7C31026B-10TCN Memory SRAM IC
  • 1 × SD Card board with SPI interface
  • 1 × PS/2 Keyboard to serial board (Optional)
  • 1 × Power supply 9V dc 15W (for LCD) or 5V (without LCD support)
View all 9 components
  • PS/2 keyboard controller
    Leon2 days ago 0 comments
    At last I wrote a controller for PS/2 keyboard in the fpga. It has a 16 key queue.
    I was postponing it and was using an external board instead, but once I started, it was easy and fun.
  • Memory block transfers
    Leon07/06/2019 at 14:52 0 comments
    In the beginning Lion CPU was more like a risc cpu all operations were done between registers and the only way to alter memory was by storing a register. I added instructions based on the requirements of the software I developed for Lion computer so now it is more cisc than before. I keep adding instructions that i think are useful or add speed as long as unused opcodes are available.
    I added ram block transfer commands. The IDX register that was used as a loop counter and index, is used by the transfer instructions to hold the number of words to be moved.
    Instructions MTOM, MTOI, ITOM, ITOI with two arguments An1,An2 move fast blocks of words starting from memory or IO address An2 to memory or IO address An1.
    Instructions NTOM, NTOI with arguments An1,N or An1,An2 fill the block pointed by An1 of size IDX+1 with the 16 bit value N (or An2).
        MOV A1,buffer1
        MOV A2,buffer2
        SETX 99
        MTOM A1,A2  ;copy the 100 words block starting at buffer2 to buffer1
        SETX 99
        NTOM A2,0   ;fill buffer2 with zeros
    These new instructions drastically improved scrolling routines speed
  • Memory Pages in Lion
    Leon06/28/2019 at 13:53 0 comments
    When I first started to design the cpu I thought that 16bit address bus is ok for a homebrew cpu but after I made the Lion computer 64K rom+ram seemed very small although it used separate video and sprites ram. I wanted more memory and the more convenient way to do it is using pages. So I added 3 more address pins to lion cpu and added the necessary commands to support 8x64K pages.
    The SR register was extended from 8 to 16 bits and now the 9 most significant bits bit15 to bit7 hold the current code (bit15-bit13), data (bit12-bit10) and stack page (bit9-bit7).
    Instruction SDP sets the current data page, SSP sets the current stack page
    PJMP jumps to another address/code page.  PJSR jumps to a subroutine to another address/page and PRET returns.
    Also another register named OtherDataPage ODP assists in data transfers between pages by holding a source or target page for use with instructions PMOV PMOV.B
    Interrupt routines always use page 0 as a code page.
    I'm currently testing the functionality of this implementation and need to make more changes to the assembler
  • Keyboard
    Leon05/24/2019 at 16:49 0 comments
    Fixed some issues with the keyboard, now Shift and Caps Lock work well, although I cannot turn the Caps led on due to the external controller board I use limitations. Maybe I have to build my own as i did with everything else although I find it not so interesting.
  • Upgraded text mode 0
    Leon01/08/2019 at 15:17 0 comments
    Since I made a second video mode for graphics and added more vram I used the extra ram to also upgrade the first video mode for text so its now 640x240 pixels and with a 8x8 font can display 30x80 characters in two colors per character from 16 available.
  • Second sprite controller
    Leon01/03/2019 at 16:19 0 comments
    Added a second parallel sprite engine so now 28 sprites are available for mode 1 in 8k sprite ram. It is synchronized using the vertical synch signal with the video controller that generates the first 14 sprites. Sprite ram is now split in two 4k independently addressed units so each sprite controller has its own ram. Sprite ram is mapped in I/O space at address 16384.
    I can any time easily add one or two more sprite controllers to have 42 or 56 sprites.
  • 16 sprites
    Leon01/02/2019 at 21:54 0 comments
    Number of mode 1 sprites increased from 10 to 16.
  • Older Logs
    Leon12/28/2018 at 13:18 0 comments
    Older project logs can be found in the first Lion project page at http://users.sch.gr/tliontakis/index.php/my-projects/13-vhdl-cpu
  • Load screen & extended memory
    Leon12/25/2018 at 21:37 0 comments
    I added a INT 5, A0=13  system routine that loads in screen memory, files directly from the SDCard so I can easily display saved screens. Also I added a command LSCRN "filename", address in Tiny Basic.
    I added also a command XMOV in CPU/assembly that can move data to and from "extended memory" so now Lion can access more memory than the 64K ram (currently 128K). The "extended" memory can be used only for data not for programs.
    -- 28/6/2019 XMOV commands and extended memory no longer exist, they were replaced by page memory and commands
View all 9 project logs
Dusan Petrovic wrote 03/25/2019 at 12:32 point
This project is a great addition to the #Homebrew CPU list. Thanks Leon!
Leon wrote 03/25/2019 at 19:09 point
thank you
f4hdk wrote 03/24/2019 at 14:37 point
Leon wrote 03/25/2019 at 01:18 point
thanks for the tip
Goran Mahovlic wrote 01/08/2019 at 10:15 point
It would be great to see your console on our FPGA :) http://radiona.org/ulx3s/
Leon wrote 01/08/2019 at 14:59 point
Nice board!
Goran Mahovlic wrote 01/08/2019 at 22:43 point
Tnx, it was made for university in Zagreb(Croatia), and at some point we will try to push it to market.
Leon wrote 01/08/2019 at 00:56 point
thank you Goran
Goran Mahovlic wrote 01/07/2019 at 14:45 point
Great work!!!
