I almost finished the porting of Small-C to the Lion32 computer with 32bit integers instead of the 16bit that the original made for x86. I also made a linker for combining the object files it produces to a single executable file.
I had a hard time with the different cpu endianness and the different cpu word size but I believe now I have solved all these problems.
I almost finished the c library routines. Tiny Basic in Lion plays the role of a command line interpreter and so I added file and memory handling routines to it.
If I could add structures in Small-C compiler it would be perfect and floating point would be nice too.
Leon
we wait for llvm backend ;-)
