Started working on the electronics
A project log for Freeform robot
A simple robot built from wire
robsoncoutoRobsonCouto 12/19/2018 at 22:400 Comments
The ultrasonic sensor is held to the servos with double sided foam tape. I also had to shorten the servos' cables to achieve a cleaner look, otherwise they would be sticking out of the robot.
Started to solder the basic microcontroller circuit, with the 16MHz crystal connected to the correspondent pins. I chose the ATmega8 simply because I have many of them laying around. It is Arduino compatible, although with only 3 PWM pins. For this task, however, it is more than sufficient.
