Gimme your digits
A project log for wirez80
Z80 machine with a hex keypad and 7-segment displays built on a cylindrical wireframe
matsengmatseng 12/21/2018 at 22:100 Comments
Tonights excersize  in straightening and soldering was to solder up the 7-segment displays.  I had three 2-digit  displays in a box - they turned out to be green instead of the more common red ones, but why not? Green is a nice color :-)
I cut up eight lengths of wire and stuck them between two small PCBs as a jig to keep the wires parallel and steady while soldering.  I could fit 6 wires beneath the display and then put the two remaining wires outside of the display.
The inner six wire jigged up by pcbs
The soldering was rather easy. I used thinner wires as jumpers between the four inner wires and the legs of the displays. I was a bit afraid that it would not be sturdy enough, but since each of the wires in the bus are connected to six pins on the displays the thinner wires are enough to hold them down steady.
I definitely need to clean up the joints from the flux - it looks a bit too messy to be really pretty right now.
Solder side of the displays
I managed to get a bit of superglue on the face of the displays ;-(   I'm not sure how to clean it up right now. Maybe I just can light sand the face, or maybe it'd be easier to put a green filter over the displays - that will increase the contrast as a bonus.
Display tops with glue residues
