Do not disturb my circles
A project log for wirez80
Z80 machine with a hex keypad and 7-segment displays built on a cylindrical wireframe
matsengmatseng 12/23/2018 at 10:514 Comments
It is said that the last words uttered by Archimedes before being killed by a Roman soldier while drawing in the sand was "Nōlī turbāre circulōs meōs!"  which translates to "Do not disturb my circles".
Well, my circles - or maybe I should say rings -  that should have been put nice and straight on top of each other are for sure disturbed.  ;-)
They ended up a bit more crooked and askew than I had hoped for, and while I can strive for perfection I don't demand it from myself, so for the time being this is good enough.
Even if I had printed some jigs for holding the rings in place while soldering the resistors that I use as spacers/structure between the rings it was really hard to make it look even remotely nice.
3d-printed spacers for holding the rings while soldering
Well, this is how the first cylinder ended up. Maybe the second cylinder with 16 rings for the address bus will be a bit prettier now that I have some experience with them.
The cylinder-of-rings that will become the D0-D7 databus
Yann Guidon / YGDES wrote 12/23/2018 at 15:35 point
Resistors as spacers ?...
matseng wrote 12/23/2018 at 16:25 point
I had a bunch of 1 megs at home. It would have been better with 10 megs of course, but I think it will be ok.
matseng wrote 12/23/2018 at 16:26 point
Could have used 1pf caps as well, but I don't have that low a value in enough quantity...
Dr. Cockroach wrote 12/23/2018 at 12:59 point
Hey, looks good to me :-D
