More rings and tower
A project log for wirez80
Z80 machine with a hex keypad and 7-segment displays built on a cylindrical wireframe
matsengmatseng 12/29/2018 at 11:030 Comments
Now when the UI part is done I spent some time to get cylinder/tower ready to start hook up the CPU and memories to it.
The sixteen rings was easy to make with the new jig I 3d-printed to keep the rings steady while soldering together the ends of them. (The jig reminds me of something - maybe the Quake logo?)
The 16 address bus rings and the jig
Now that I got some experience from soldering the smaller databus it was rather easy and fast to solder up these 16 into a decently looking cylinder.
Then I (temporarily) patched the two separate cylinders together with three wires to make some distance between the buses where the ICs will be soldered.
The slightly leaning tower of Pisa - I.E the data & address busses
