Solder the D-Sub connector(s) before soldering an IDC connector (2-row header), otherwise it will be much harder to solder the D-Sub(s).
Be sure to understand the pin numbering.  The industry-standard correlation has IDC26-1 going to DB25-1 but all other pins are not one-to-one.  See pin numbering above or in the spreadsheet file.  The PCB is labeled on both sides with the IDC/header pin numbers (1, 2, 25, 26).  It is labeled on one side with D-Sub pin numbers with F for female connector and M for male connector.  The IDC header needs to go on the top side of the PCB as shown below to get the proper pinout on a ribbon cable attached to the header.
Here is the top side of the PCB:
And here is the bottom side:
D-Sub connectors with pins (shown below) don't fit tight on the PCB unless the pins are bent inward.  Bending the rows of pins inward is more-or-less a requirement for proper soldering.
Solder-cup D-Sub connectors like this fit snugly.
Here is a board fully assembled with three connectors (sitting on the handle of a screwdriver).
The PCB gerbers are available in the file section.  The PCB is also available for ordering from OSH Park at https://oshpark.com/shared_projects/vJyVem1K
