WEMOS Motor Shield firmware for steppers (I2C)
Use your Wemos motor shield with steppers motors I2C custom slave interface
A new application for cheap WEMOS Shield Motor DC driver From full step to 32 microsteps voltage sinoidal microstepping.Editable microstep table ,Many steppers as I2C addresses free in your app.Commands speed, target and resolution.Arduino skecth example, working on ESP82266 and AVR micros..Beta but functional .Includes windows example for FT260 i2c Dongle.Source code and Firmware availalble on Github.
I2C code  based on interrupts , no polling code.
I2C Clock Speed 100Khz
Address 0x32 (editable at HEX file)
Commands
MOTOR_GET_COUNT 0x02: Send 0x02, Read int32 (4 bytes)
MOTOR_SET_COUNT 0x03: Send 0x03 int32 (5bytes)
MOTOR_SET_TARGET 0x04: Send 0x04+ int32 (total 5bytes)
MOTOR_GET_TARGET 0x05; Send 0x05, Read int32 (4 bytes)
MOTOR_SET_TICKS 0x06: Send 0x06+ int32 (total 5bytes)
MOTOR_SET_DIR_RES 0x07: Send 0x07+ int32 (total 5bytes)
 MOTOR_SET_PRESCALER 0x08:Send 0x08+ int32 (total 5bytes)
MOTOR_SET_WAVE_SCALE 0x09:Send 0x09+ int32 (total 5bytes)
MOTOR_SET_SPEED:0x0A:Send 0x0A+float (total 5bytes)
MOTOR_SET_TARGET_SPEED 0x0B:Send 0x0B+float (total 5bytes)
MOTOR_GET_TARGET_SPEED 0x0C
MOTOR_GET_SPEED 0x0D
MOTOR_GET_DIR_RES 0x0e
Values for set speed microsteps/s signed  4 bytes float
SET_SPEED set speed with no acceleration SET_TARGET_SPEED accelerate from current set speed.
Speed timer frecuency 48khz tick 20,8us At this moment only min value -65535 to +65535 speed 65535-> 1,3s per microstep positive direction speed 30000->0,65s per microstep positive direction speed -15000->0,3125s per microstep negative direction
Resolution 1-> 32 msteps 2->16 4->8 8->4 counter is always 32 microsteps resolution
Arduino test code (works on AVR and esp8266)
#include <Wire.h>
#define SLAVE_ADDRESS_1 0x32
//Set Commands
#define MYSLAVE_SET_REG 0x01
//GET commands
#define MOTOR_GET_COUNT 0x02
#define MOTOR_SET_COUNT 0x03
#define MOTOR_SET_TARGET 0x04
#define MOTOR_GET_TARGET 0x05
#define MOTOR_SET_TICKS 0x06
#define MOTOR_SET_DIR_RES 0x7
#define MOTOR_SET_DIR_RES 0x07
#define MOTOR_SET_PRESCALER 0x08
#define MOTOR_SET_WAVE_SCALE 0x09
#define MOTOR_SET_SPEED 0x0A
#define MOTOR_SET_TARGET_SPEED 0x0B
#define MOTOR_GET_TARGET_SPEED 0x0C
#define MOTOR_GET_SPEED 0x0D
#define MOTOR_GET_DIR_RES 0x0e
#define PRINT_WAVE 0x44
void setup() {
 Wire.begin();        // join i2c bus (address optional for master)
 Serial.begin(9600);  // start serial for output
int32_t read_wms( uint8_t command, int address)
{ int32_t pos;
  char *pointer;
  char c;
  pointer=(char*)(&pos);
 Wire.beginTransmission(address);
  Wire.write(command);
  Wire.endTransmission();
  delay(5);
   Wire.requestFrom(address, 4);
    while (Wire.available()) {
    char c = Wire.read();
    (*pointer++)=c;
    return pos;
void write_wms( uint8_t command, int address,int32_t value)
  char *pointer;
  pointer=(char*)(&value);
  Wire.write( command);
  Wire.write(pointer,4);
void write_wmsf( uint8_t command, int address,float value)
  char *pointer;
void loop() {
 //goto from 0 to 1000
 int32_t pos=0;//set motor counter to 0
 int32_t target= 10000;//set desired position 10000
 int32_t speed=300;//20,8 us * 300 =0.624s  ->16,02 microsteps/s
 float speedf=2000.0;//2000 msteps/s
 write_wms(MOTOR_SET_COUNT,SLAVE_ADDRESS_1,pos);//send counter
 write_wms(MOTOR_SET_TARGET,SLAVE_ADDRESS_1,target);//target set
// write_wms(MOTOR_SET_TICKS,SLAVE_ADDRESS_1,speed);//command speed
 write_wmsf(MOTOR_SET_SPEED ,SLAVE_ADDRESS_1,speedf);//command speed
 while ( (pos=read_wms( MOTOR_GET_COUNT ,SLAVE_ADDRESS_1))!=target)
  delay (100);
  Serial.println(pos);}
//motor will turn an stop until reach 1000 counter value
//now we command back 0 pos
  target= 0;//set desired position 1000
 speedf=-2000;//20,8 us * 300 =0.624s  ->-16,02 microsteps/s
 int32_t resolution=2; //motor will no run on 16 msteps
 write_wms(MOTOR_SET_DIR_RES,SLAVE_ADDRESS_1,resolution);
 delay (...
tb6621_addr34.hex
firmware address 0x34 HEX
hex - 16.89 kB - 03/27/2021 at 15:59
Download
tb6621_addr34.bin
firmware address 0x34 BIN
octet-stream - 5.98 kB - 03/27/2021 at 15:59
Download
tb6621_addr32.hex
firmware address 0x32 HEX
Download
tb6621_addr32.bin
firmware address 0x32 BIN
Download
wemosshield.ino
Generic Arduino tester
ino - 2.79 kB - 03/27/2021 at 15:57
Download
  • Set speed command as Float number
    Angelote01/14/2019 at 19:43 0 comments
    Set speed  as usteps/s command  as float 4 bytes (24,8)format added
    Update Delphi  client for FT260 I2C DONGLE
  • Now tested with WEMOS D1
    Angelote12/28/2018 at 12:53 0 comments
    I have uploaded a arduino Skecth and its works fine with WEMOS D1.
  • Basic and Optional Components
    Angelote12/26/2018 at 16:25 0 comments
    Wemos Motor Shield
    STLink v2 clone (for developing) firmware can be upload by using any usbserial dongle.
    FT260 (to talk I2c from your PC )
    ch340 usb-serial ttl dongle
View all 3 project logs
View all instructions
julienhogert wrote 03/25/2021 at 14:07 point
Angelote  ! Thank you for taking the time to make theses changes ! It works perfectly on esp8266 ! that's super nice ! I also tried on wemos D32, but it didn't want to compile because of : Wire.write(pointer,4); I tried putting off the length argument, and it looks that is close to work (It make fews steps forward/backward, but not working the same (probably because the speed is not well written I suppose) / I tried to use write_wms, instead of write_wmsf : same problem.
Last more little thing: Why did you choose to set the speed in positive and negative?  because the difference between the position and the target should give the direction ? It should be easier to integrate the calculation of the sign's speed, inside the STM32, no? but that's a question. Thanks again for your work.  Last year, I did a wrapper-library for your code, I'll probably update it and put it on github next week!
julienhogert wrote 03/25/2021 at 14:24 point
OK ! I made it works with the esp32. The subtlety is used is to replace :
by
for(int i=0;i<4;i++){
    Wire.write(pointer[i]);
Tanks again Angelote !
julienhogert wrote 03/23/2021 at 10:18 point
hello Angelote ! A lot of people, including myself, would love to see your code working !   I looks like it miss just a small ajustement to make it works. How can we help you to achieve this v.2. Because for sure, what you purpose is the smallest and most convenient solution for esp32/esp8266 wemos board. Thanks, Julien
Angelote wrote 03/24/2021 at 11:37 point
Hello Julien , i have uploaded update,source  compiled firmware and arduino skecth using a new function to send float value to i2c.Firmware is working well with ft260 i should on arduino  in the same way .
Angelote wrote 03/24/2021 at 17:57 point
I have uploaded a video demo for the current update Firmware.
https://youtu.be/1fO4gqK1UaU
Seventh Dwarf wrote 02/22/2021 at 10:33 point
Hello,
let me first thank you for the great work. I think it's the correct idea to move the stepping motor control into the local MCU on the shield, instead of trying to mimic this on the main MCU.
However, the changing from integer to float for the speed doesn't seem to work correctly. Independently what I set for the speed, the actual position, as readback value from the MOTOR_GET_COUNT, goes around zero, like already mentioned by julienhogert.
Following initial settings:
pos = 0
target = 1000
speed = 100.0f
pos goes like 0,0,0,0,0,2,4,5,4,4,4,5,5,5,4 and so on.
Other speed settings give similar results. Changing the endianess of the transmitted float doesn't help.
What is the range of speed? Is it -1.0 to +1.0 or is it -65536.0 to +65536.0 or any other?
Is the float format of the Arduino and the STM32 lib identical?
Thanks for your kind support
best regards
Seventh
Angelote wrote 03/23/2021 at 18:20 point
Sorry for my delayed response .We are living are weird times...
Last time I updated this project a year ago .I haven `'t checked with  wemos board but from  my FT260  USB <->I2C  device  the board is aceptting  and  executing all speed goto  commands  correctly.
I will revise my arduino  wemos skecht which probably is out of  date.
Daniel Herrera wrote 10/11/2020 at 01:02 point
Hi. Do you think this firmware can be ported to the v2.0 board version? So far, it seems I will have to obtain v1.0 board in order to work with stepper motors. Cheers.
fred wrote 06/07/2020 at 14:11 point
Hi, i uploaded the new firmware and now i can get the i2c address, is is 0x30. Uploading the .ino and looking in the terminalwindow i see -1,-1,-1 etc etc.
can someone tell me what i did wrong
br
fredj
julienhogert wrote 03/20/2020 at 18:02 point
Hello Angelote, I tried today your new version of the firmware, but didn't find a way to make it works. I started over with your example, trying to integrate the new "ideas". I put inside the code the questions I Had, Could you please, take a look, and maybe send it me back on GitHub? Here is the code:
 https://github.com/julienhogert/WEMOS-MOTOR-SHIELD-I2C-STEPPER/blob/master/arduino/wemosshield_new_firmware.ino
Thanks ! Julien
Angelote wrote 03/20/2020 at 18:32 point
I have test latest  code  with the FT260  I2C pc Interface  only.(and  it works fine)
I gonna  make changes on WEMOS Skecth demo to show how to use thew new features, stay tune.
julienhogert wrote 03/23/2020 at 21:12 point
Hello Angelote ! I tried again today to make it works ! but without success, If you have a little time to make an update of your code, it would be great ! Thanks, Julien
Angelote wrote 03/15/2020 at 21:51 point
Sure .I dont remember´just  now If  I uploaded the latest firmware to github  i will check and inform you.
julienhogert wrote 03/15/2020 at 21:10 point
Hello Angelote ! I came back to steppers and I'd like to use the lasts improvements of your code. With the new timer, and the setSpeed... Is there any possibility to upload it? Thanks again for the very good work you did ! Julien
Angelote wrote 03/16/2020 at 19:15 point
I have checked and uploaded firmware with 0x32 and 0x34 adresses at github project repository and update description of new commands at description,Speed ca be set in microsteps/s using 32bit signed float for instant o accelerated settting
Angelote wrote 03/16/2020 at 19:26 point
I forgot you can scale source voltage amplitude with WAVE_SCALE command.Its integer value indicates percentage o full wavE MAGNITUDE values from 0 to 100 by default 50%
julienhogert wrote 03/16/2020 at 21:10 point
Thanks a lot ! That's a very god job. I'll try it these days and give you a feedback if you want ! Thank again ! Julien
Angelote wrote 03/17/2020 at 16:35 point
I just have uploaded corrected firmware,because speed was not set to zero on boot.
Cohbra11 wrote 04/21/2019 at 01:11 point
Thank you everyone for your work on this!  I have what I assume is a simple question, but I cannot figure out how to make use of the standby function using I2C.  I don't see any mention of it in the example, and I would like to have the ability to turn off all power to the motor when it is not needed.
Brian
julienhogert wrote 02/01/2019 at 20:59 point
Hey, I still continue working with your "hack". It's really fantastic.
So I still put flesh on the library I began for Wemos_stepper. you can find here :https://github.com/julienhogert/WEMOS-MOTOR-SHIELD-I2C-STEPPER/tree/master/arduino
It's a work in progress, so, there are some function which may not work well, but, just to take a look.
One thing I found very counter-intuitive in your proposal, is the speed. Why didn't you put it in step/s ? So to make the conversion, I make this ugly thing:
speed_i2c=float( float(STEPS_PER_REV/float(speed)) / float(FREQUENCY_MS*BASE_MS*STEPS_PER_REV) );
but didn't find a way to simplify it. Also, in you system, the maximum of Speed is quite low, something like 700/800 steps/s (when speed_i2c is egal to 1 ), no?
Also, when I change the Microstep, I term of speed, nothing change. I don't go quicker when I'm in fullstep than in quarter... so, how can I go faster? changing the tick?
Last little thing that should be good: When you change the target. the sign of speed should be changed automatically. I did it on the library, but is it difficult to put it in the MC of the stepper? I tried to look a little bit of your code, but still too complicated for me.
Well, again, thanks a lot for you're job. and if you're interested about the Arduino programmation, take a look at the library I did, based on your work and maybe we can talk about this also, because in a way, it's the missing part of the big part you ever did.
Thanks, Julien
Angelote wrote 02/01/2019 at 21:13 point
Thank you Julen , I have made some  modifications including setting current speed and  target in steps/s  using  signed 32bit float  and acceleration/deceleration ramp .
void set_speed(float speed)
dir=signf(speed)*resolution;
ticks_x=abs((int)(freq/(speed)));
rep_counter=0;
if (ticks_x>0xFFFF)
rep_counter=ticks_x>>16;
ticks_x=ticks_x/(rep_counter+1);
if (dir==0) ticks_x=0xFFFE;
TIM16_ARR = ticks_x;
TIM16_RCR=rep_counter;
Now im using TIMER16 which  has a built  repetition register so  I have reduced prescaler value from 1000 to 27  to reach higher speed ratios.
I will upload last  version with fully tested.
julienhogert wrote 02/01/2019 at 21:22 point
So nice ! When it will be available, make me a sign ! About Acceleration/deceleration, I also made a library to manage sequences of movements with all the easing functions, recycling this library : https://github.com/tobiastoft/ArduinoEasing. If you want to take a look, tell me and I'll upload my code. Last thing I was working on, is the possibility of an autospeed mode, to follow a sequences of targets at regular interval, typically to follow a complex movement...
Angelote wrote 01/10/2019 at 21:14 point
I´m  migrating the development enviroment from Code:Blocks to  EMBitz IDE  which bundles  its own GCC-ARM  compiler version.I will include a stripped version of opencm3 with is opensource and more easy for developing than  ST device library.
Angelote wrote 01/10/2019 at 21:07 point
Hello
You may remove delay statements,I had got  some command overlap issues before, but now All seems i OK.My sofware is all interrupt driven  and  should not block.
Target is the  place to stop, consider, there is not a "Goto" command implemented onto  the microcontroller still.Then you have to command " the rigth direction".
I  still have to write  speed up and down timer interrups acceleration routines but it´s a piece of cake.
Resolution is the number of microsteps  you take each timer overflow .Using the 32msteps as base its posible to switch stepper resolution   "on the fly" keeping a coherent value for the step counter.
Yes there is  fixed 10bits  sine wave table as reference  in FLASh, MOTOR_WAVE _TABLE will scale those values into a writable array, value for this is from 0 to 100, (percentage of fixed value).Probably I will make the fixed table  user writable for microstepping calibration,as we know as stepper has its own optimized wave.
There is still a lot of work but I enjoy it.
julienhogert wrote 01/10/2019 at 17:12 point
Hello ! Thank you so much for the job you've done ! For a long time I was expecting what you did ! I made a little library to integrate your code. you can find it here : https://github.com/julienhogert/WEMOS-MOTOR-SHIELD-I2C-STEPPER/tree/master/arduino
It's very basic, but just made it to be more convenient !
I have some questions :
Why did you put  delay(5), in the i2c command?
Why do you have to inverse speed when you already set the Target?
I will probably tweak it in the library to have only positive values.
why did you invert the resolution? Resolution 1-> 32 msteps 2->16 4->8 8->4 counter is always 32 microsteps resolution. I made a function to put it in a more convenient way (1:full step, 2:half, 4:quarter...)
You put: voltage sinoidal microstepping. does it mean that we can manage the current/voltage/torque of the stepper?
Once again, thank you so much for your job,
I can only help with the "easy part" of the code, but if you need it, I'll be there ! Thanks,
Julien
