Only some details are pendig in order to be able to launch next week. In the las few days,
- The rocket was painted
- The old servo cables were replaced with a more robust 4 wire cable.
- The old PCB connectors for the servos were replace twith more robust connectors.
- The switch cover that ensures that the parachute chord does not entangle with the switch was glued.
Still pending,
- Install arming connection for igniter
- Glue the bearing to the gimbal
- Thoroughly test the complete system
