Beezy is a blinking badge. Here are three variants of Beezy as circuit sculptures.
[1] Beezy and its flower: push LEDs outside the PCB, arrange them in a circle as a form of flower, and use air soldering to connect LEDs back to the Beezy.
[2] Two flowers with hard wire air-soldering: the circuit is similar to the Beezy but with all pins exposed. Two five-led flowers. One is red and the other red.
[3] One flower with soft wire air-soldering: 7 LEDs are soldered closely and arranged as the centre of the flower. Then solder soft wires back to the circuit.
