Hackaday.io Hackaday.io
Sign up Log in
Spheron
An omni-directional autonomous spherical rolling robot.
varshith-solipuramVarshith Solipuram
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
201 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 13
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
286
0
201
0
Team (1)
  • varshith-solipuramVarshith Solipuram
Join this project's team
hardware
shelved project
Related lists
todo
g
This project was created on 12/30/2018 and last updated 7 years ago.
Description
Inspired by BB-8 from Star Wars, this was my attempt to build an autonomous spherical rolling robot. Simply, a drive unit with two diametrically opposite motors is freely suspended inside a spherical casing and an obstacle avoidance unit on the outside of the casing is coupled to the internal unit via Neodymium magnets. Two ultrasonic ranging sensors mounted at 45° to the tangent will detect obstacles and communicate to the unit inside via a 433MHz radio.
Details
Files
Spheron_1_nano.ino
ino - 2.36 kB - 01/06/2019 at 04:30
Download
Spheron_1_Uno.ino
ino - 3.25 kB - 01/06/2019 at 04:30
Download
Components
  • 2 × Arduino For the drive unit and the sensor unit.
  • 1 × Voltage regulator
  • 1 × Neodymium Magnets
  • 1 × A spherical casing with a smooth outer surface.
  • 2 × Ultra-Sonic ranging sensors
View all 13 components
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
I built a Hybrid Delta Robot using Arduino & Servo motors. Delta robots are widely used in factories for high-speed pick and place operation
Project Owner Contributor
DIY Industrial Pick-And-Place Robot | Delta Robot
robotics-everydayRobotics Everyday
Building quadruped robot
Hobby servos quadruped robot Build
oilspigotOilSpigot
In compact robots, the chassis is usually made with two independent drive wheels and two passive wheels or balls, while the turn is carried
RATEL - five-wheel FLL Lego robot
sergei-v-bogdanovSergei V. Bogdanov
A robot vacuum made with Arduino and MDF
DIY Robot Vacuum
mr-cookieMr. Cookie
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Spheron", please tell us the reason.
Send message
Remove Member
