• Desolder time
    Tillo01/01/2019 at 14:18 0 comments
    Well to fit in Pi Zero into that case, some LEDS need to go.
    As well as the switch. So I unsoldered stuff. Unfortunatly some through hole contacts fell out. Thank god, they weren't critical for  the project. Actually it was even useful, since i could use the holes to put the wires for the USB data lines.
