Well, that took forever to upload
A project log for 12 Servo Hexapod
A 2 DOF hexapod
actualdragonActualDragon 05/12/2018 at 21:540 Comments
Next up is to copy that code for 3 legs, and reverse it for the other 3. (For the Tripod gait)
CORRECTION: In the video, I had the jumper ON, but then it shorts out the computer (they have protection for that and you have to restart it). If the jumper is off I found, it works just fine with the computer, and allows you to use a battery.
