amp insect
A simple AB class audio amplifier using lm386n in a free form electronics fashion
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
it is a AB class amplifier made using a lm386n audio power amplifier run o a 9 volt battery
three capacitors are used as decoupling capacitor, filter and bypass capacitor .
audio input is positive input using a 3.5 mm audio jack and output is through the earphone speaker attached to the front .
