Schmitt Trigger from 2 NPN Transistors
A project log for Light Sensitive Kinetic Sculpture Tribute To Dad
A kinetic sculpture that reacts to light and shadow, constructed mostly from components my late father had recycled from other electronics
bornachbornach 01/06/2019 at 17:310 Comments
This logic level Schmitt trigger uses 2 NPN BJTs and resistor values I copied from another YouTube video that describes how it works:
I didn't put much effort in planning how to layout the components. The form just emerged from how everything needed to be connected without resorting to adding extra wire. The result was this tight knot of components.
