Yagi_Telescoping_Mount_v2_halfsz.gcodegcode of the @ 0.1 vertical height (res), 30% honeycomb infill and 5 layers rectilinear perimeters for the MPSM V2gcode - 6.82 MB - 01/18/2021 at 06:33 |
Yagi_Telescoping_Mount_v2_halfsz.stlVersion 2.1 half length, 42mm design .stlStandard Tesselated Geometry - 261.12 kB - 01/18/2021 at 06:32 |
Yagi_Telescoping_Mount_v2.gcodegcode of the @ 0.1 vertical height (res), 25% honeycomb infill and 5 layers rectilinear perimeters for the MPSM V2gcode - 15.28 MB - 01/18/2021 at 04:43 |
Yagi_Telescoping_Mount_v2.stlVersion 2 .stlStandard Tesselated Geometry - 161.51 kB - 01/18/2021 at 04:39 |
Yagi_Telescoping_Mount_v2.rsdocVersion 2 in the DesignSpark Mechnical file format.rsdoc - 144.38 kB - 01/18/2021 at 04:39 |
Telescoping_Yagi_ToDoList.docxTo Do List of next tasks I need to complete. Scribing antenna and associated boom length resonant frequencies and color coding those location can be added to the list. Needs to be updated.document - 6.55 kB - 01/08/2019 at 22:42 |
RDF_Telescopic_Yagi_Antenna_Calculator.odsNot the prettiest spreadsheet... though aids in theoretical calculations. Needs to be updated.spreadsheet - 18.89 kB - 01/08/2019 at 22:42 |
Yagi_Telescopic_Element_Mount2.STLSTL file for the raw Antenna Element MountStandard Tesselated Geometry - 26.55 kB - 01/08/2019 at 22:34 |
Yagi_Telescopic_Element_Mount2.SLDPRTSolidWorks file for the raw Antenna Element Mountsldprt - 122.25 kB - 01/08/2019 at 22:34 |
