RELAY COMPUTER
computer science + relay technology
My ultimate goal is to build a relay-based version of my SANX-I microcomputer:
https://hackaday.io/project/162186-sanx-i-microcomputer
SPST switch: digital model & component for simulation.
SPDT relay: digital model & component for simulation.
1-bit gates.
AND, OR, XOR, NOT
Full adder/subtractor.
Phase #1: design & simulation.
N-bit comparator.
T flip-flop.
Asynchronous (ripple) binary counter.
1-bit register connected to a bus.
When WRITE changes from 1 to 0, the value on the bus is stored in the register. When READ is 1, the value stored in the register is transferred along the bus.
1-bit memory: MEM[X,Y].
ROM (16x1, 256x1 & 32x8).
N-bit ALU.
N-bit ALU + comparator.
8-bit comparison & zero flag with just 3 additional relays. Comparison will require 2 instructions: "A-B" + "check flags".
  • SPDT solely
    Javier Piay (PROPHYCOM)01/10/2019 at 11:08 0 comments
    I'm aware of other great relay computing designs using multi-pole relays and/or other components like resistors, capacitors and diodes. I will try to use SPDT relays solely and avoid race/hazard conditions. I use pull-down resistors for simulation purposes and to couple relays with electronics, but these resistors are not part of the logic circuit.
    Let's see how far I can go...
View project log
Javier Piay (PROPHYCOM) wrote 01/12/2019 at 22:02 point
What about the computer architecture?
Well, that's the easy part ;)
#SANX-I MICROCOMPUTER
Yann Guidon / YGDES wrote 01/12/2019 at 21:17 point
For the ALU, have a look at   #Simple Relay ALU  :-)
it uses diodes but it's pretty smart !
Javier Piay (PROPHYCOM) wrote 01/12/2019 at 21:43 point
I'm already aware... Thanks!
Yann Guidon / YGDES wrote 01/10/2019 at 04:23 point
That first relay ripple counter looks... complicated :-P
This one has only 2 relays per stage : https://www.youtube.com/watch?v=BE2F9dvAI-Q
The relevant log is there : https://hackaday.io/project/159762-hardware-assembler-emui/log/155764-binary-counterdivider-with-relays
Sophi Kravitz wrote 01/10/2019 at 03:53 point
Like! More please 😀
