SPDT solely
A project log for RELAY COMPUTING
computer science + relay technology
Javier Piay (PROPHYCOM)Javier Piay (PROPHYCOM) 01/10/2019 at 11:080 Comments
I'm aware of other great relay computing designs using multi-pole relays and/or other components like resistors, capacitors and diodes. I will try to use SPDT relays solely and avoid race/hazard conditions. I use pull-down resistors for simulation purposes and to couple relays with electronics, but these resistors are not part of the logic circuit.
Let's see how far I can go...
