If you have an alternative as U-blox, Simcom, Fibocom .. etc
RUN AWAY FROM QUECTEL !!!
Platforms: Arduino, OpenCPU, ThreadX
Modules: M66, MC60, BC66, BG96
https://github.com/Wiz-IO/platform-quectel
Details
Quectel BG96 - ThreadX and Arduino - comming soon...
Short press Auto-detected: /dev/ttyUSB0 Uploading: program Wait for Power ON or Reset module <.........................................> DONE Starting <.......... ERROR: DA 1 status *** [upload] Explicit exit, status 2 ===================================== [ERROR] Took 5.91 seconds ===================================== The terminal process terminated with exit code: 1
Long Press Auto-detected: /dev/ttyUSB0 Uploading: program Wait for Power ON or Reset module <..................> DONE Starting <.................................................................................................................... ERROR: baudrate CONF *** [upload] Explicit exit, status 2 ===================================== [ERROR] Took 1.64 seconds ===================================== The terminal process terminated with exit code: 1
I m not use BC66-TE-B, I used another board.
I'm trying to change the repeat time of
def da_start(self, nvdm = False): from 50 to 500, it still failed to upload.
When I use windows MTK IOT Flashtool.exe, following the guidance, it succ to upload.
added support for Olimex NB IoT DevKit
https://github.com/Wiz-IO/platform-quectel/wiki/BOARD-Olimex-NB-IoT-DevKit
