For the Command Center
A project log for EyeMac
Webcam monitored fish tank addition that causes color change depending on Macintosh the fish's location.
Amanda LeighAmanda Leigh 01/18/2019 at 16:480 Comments
Stream interaction & input
STREAM! GET IT! BECAUSE ITS FOR A FISH :D
 - Install node.js and npm
 - Clone files to computer - https://github.com/hzoo/TwitchPlaysX/archive/master.zip
 - Node packages from command line npm install in folder (irc, printf)
  - Install python - http://www.python.org/download/releases/2.7.6/ (make sure python is on PATH)
 - Install python win32 package - http://sourceforge.net/projects/pywin32/files/pywin32/
OpenCV : https://opencv.org/
For the Neopixels:
Potential code;
Fader - https://learn.adafruit.com/multi-tasking-the-arduino-part-3/fader
    // Initialize for a Fade
    void Fade(uint32_t color1, uint32_t color2, uint16_t steps, uint8_t interval, direction dir = FORWARD)
        ActivePattern = FADE;
        Interval = interval;
        TotalSteps = steps;
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
This should help make the transitions nice and smooth when Macintosh is moving between quadrants. Fast transitions = jarring = scared fishy.
References:
NeoPixel UberGuide:
https://cdn-learn.adafruit.com/downloads/pdf/adafruit-neopixel-uberguide.pdf
