First try with PCB
A project log for FORCE - Force Output of Rodent Calibrated Effort
This dual-force cell monitor and reward dispenser is used to run rodent operant behavior in which animals learn to work for rewards.
lex-kravitzLex Kravitz 02/20/2019 at 19:060 Comments
The circuit on the proto-board is working but it is time consuming to build and leaves open the potential for human error in wiring.  So we decided it was time for a PCB!  We're using the OtherMill Pro to mill these.  The first attempt looks great but unfortunately it doesn't work :(
I'm checking the wiring but good news is that we got one failed PCB design out of the way - probably only 1 or 2 more attempts until this works :)
