Motor suddenly shut down before the user test start. But usually everything is works. Now even the sensor also down. I have change the wire and still mixing. Finally find out the problem is in the code. But is weird ron said. Something wrong in the code.
The low poly face already reprint. The code is 80% fixing. still need to add in stuff. Using button to calculate the angle. Ming chang usually help me in processing to do the sound effect. Adrian also teach me how to used Cura for my 3d print.
Have change servo to a more powerful motor. Cause servo not enough power to support the low poly face. The stand doing half way still prototyping. For the soldering Alden teach me and Ming chang tell me how to enhance the soldering skills. Can just ignore the sound of my singing.
Still prototyping with the low poly face. It's still not work for the projector. I need to chnage materials. For the processing and adruino i ask alden to help. Alden teach me how to make it works.
