DYNAMIC INTERACTIVITY WEEK 15
A project log for DYNAMIC INTERACTIVITY FINAL
PROJECT BY MM1701-1 FROM THE ONE ACADEMY
Eugene_chiaEugene_chia 05/10/2019 at 08:040 Comments
Motor suddenly shut down before the user test start. But usually everything is works. Now even the sensor also down. I have change the wire and still mixing. Finally find out the problem is in the code. But is weird ron said. Something wrong in the code.
Finally the whole interactive works !!!
