DYNAMIC INTERACTIVITY WEEK 15
05/10/2019 at 08:04 • 0 commentsMotor suddenly shut down before the user test start. But usually everything is works. Now even the sensor also down. I have change the wire and still mixing. Finally find out the problem is in the code. But is weird ron said. Something wrong in the code.
Finally the whole interactive works !!!
DYNAMIC INTERACTIVITY WEEK 14
05/06/2019 at 04:34 • 0 commentsThe low poly face already reprint. The code is 80% fixing. still need to add in stuff. Using button to calculate the angle. Ming chang usually help me in processing to do the sound effect. Adrian also teach me how to used Cura for my 3d print.
DYNAMIC INTERACTIVITY WEEK 13
04/24/2019 at 12:31 • 0 commentsHave change servo to a more powerful motor. Cause servo not enough power to support the low poly face. The stand doing half way still prototyping. For the soldering Alden teach me and Ming chang tell me how to enhance the soldering skills. Can just ignore the sound of my singing.
DYNAMIC INTERACTIVITY WEEK 12
04/24/2019 at 12:26 • 0 commentsMp3 coding in progress. Low poly Face have polish but havent combine together..
DYNAMIC INTERACTIVITY WEEK 11
04/11/2019 at 07:13 • 0 comments3d printer gear and wire having problem but the 3d printed stuff just left one more to go.
DYNAMIC INTERACTIVITY WEEK 10
04/11/2019 at 07:12 • 0 commentsSolving 3d print problem.
DYNAMIC INTERACTIVITY WEEK 9
03/24/2019 at 08:21 • 0 commentsThe size of the low poly a bit out of the size that i want so i need to reprint the whole model.
DYNAMIC INTERACTIVITY WEEK 8
03/24/2019 at 08:20 • 0 commentsThere are a lot of problem with the 3d low poly face file. Still fixing low poly model.
DYNAMIC INTERACTIVITY WEEK 7
03/13/2019 at 15:59 • 0 commentsThe main problem for me is the low poly human face. because there are some 3D spftware error still need to be fix.
DYNAMIC INTERACTIVITY WEEK 6
03/06/2019 at 13:47 • 0 commentsStill prototyping with the low poly face. It's still not work for the projector. I need to chnage materials. For the processing and adruino i ask alden to help. Alden teach me how to make it works.
