CCLib_proxy.inoModified Arduino Sketch for the Wemos D1 mini with modified pins and increased delay() time (See instructions for more details)x-arduino - 7.60 kB - 01/20/2019 at 19:05 |
CC2531ZNP-Prod.hexModified Firmware for use with the CCLib_proxy.You do not have to remove the second line from the bottom! This is the same file I flashed on my other adapter hex - 680.74 kB - 01/19/2019 at 21:08 |
CC2531ZNP-Pro-Secure_LinkKeyJoin_mod.hexThe firmware I used to flash one of my adaptershex - 665.61 kB - 01/19/2019 at 21:08 |
