YamPAD project log 17
A project log for YamPAD - Feature-packed open source macropad
A fully open-source, mechanical, hot-swappable, RGB backlit, QMK powered, OLED screen featuring numpad/macropad.
mattia-dal-benMattia Dal Ben 07/07/2019 at 17:390 Comments
Success at last...
IT WORKED! IT ACTUALLY WORKED!
Everything went smooth. I knew the CNC was capable of cutting aluminium, it was only a matter of debris. All dimensions seems to be ok.
 Now I can finally move on with the rest of the case...
