01/21/2019: Hall Voltage Calculator
A project log for Making Sense of the Hall Sense
The Physics Behind The Hall Effect Sensor
TheRealDubzTheRealDubz 01/22/2019 at 07:000 Comments
Added the Hall voltage calculator.  Right now I only have copper in there, but feel free to use.  The process will be the same for different materials, just plug in the correct values.
