Stereotaxic clamps and accessories!
A project log for 3D printed rodent stereotaxic device
A 3D printed stereotax
lex-kravitzLex Kravitz 10/10/2019 at 17:070 Comments
I've designed a few stereotaxic clamps for holding a drill or other equipment.  Editable 3D files are available here!
These will require a few metal parts to put together.   The M2.5 thumbscrews and brass inserts, and 8mm steel rods (~$3 each on Amazon).
Assembled drill clamp:
Stereotaxic clamp
8mm to 6mm rod clamp:
