BJT oscillators
A project log for Analog Blinken Grid
64 LEDs in a matrix on a wireframe controlled by 16 astable transistor oscillators to resemble a computer panel from a 70's TV show
matsengmatseng 01/25/2019 at 23:240 Comments
Since the LEDs are in a matrix I need to have the oscillators both push VCC into  columns and also connect GND to the rows. So I need two different types of modules for that
The oscillators themselves are just the bog-standard two-transistor, four resistors and two caps thingie.  And to be able to push and pull current I added a NPN driver transistor to eight of them, and a PNP driver to the remaining eight.
Using 1uF caps and 1M for the timing resistors I ot about 0.7Hz when running at 5 volts, slightly slower at 3 volts.
Schematics for the two types of oscillators
Eight of each of the two types of oscillators are needed for the 8x8 matrix.
Soldering the oscillators
I re-discovered the usefulness of using blu-tack to hold parts while soldering - but even  using that it took quite a while to freeform 16 oscillators with 9 parts each.
The oscillator with a NPN driver
This is one of the NPN-driver oscillators that pulls a row to ground when active. The PNP oscillators looks more or less the same except for the top transistor that is in a slightly different position to access VCC instead of GND.
