Hackaday.io Hackaday.io
Sign up Log in
Low Noise Op Amp Breakout Board
Breadboard friendly breakout board for the LT1028 ultralow noise op amp
daves-dev-labDave's Dev Lab
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
129 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
530
2
129
1
Team (1)
  • daves-dev-labDave's Dev Lab
Join this project's team
  • Purchase at B.G.Micro
ongoing project
This project was created on 01/22/2019 and last updated 7 years ago.
Description
The project is to create a breadboard friendly breakout board for the LT1028 ultralow noise op amp commonly used for audio applications. The board is designed to use two LT1028 boards for stereo applications.
Files
LT1028-datasheet.pdf
PDF Datasheet for the LT1028 Ultralow Noise Precision High Speed Op Amp
Adobe Portable Document Format - 712.90 kB - 01/22/2019 at 01:42
Preview
LT1028-board-reva.zip
Eagle CAD Design Files - This work is licensed under a Creative Commons Attribution-NonCommercial 4.0 International License. CC-BY-NC 4.0, Copyright (C) 2018, David Anders. All Rights Reserved.
Zip Archive - 11.06 kB - 01/22/2019 at 01:15
Download
lt1028-board-reva.pdf
PDF Schematic - This work is licensed under a Creative Commons Attribution-NonCommercial 4.0 International License. CC-BY-NC 4.0, Copyright (C) 2018, David Anders. All Rights Reserved.
Adobe Portable Document Format - 10.70 kB - 01/22/2019 at 01:15
Preview
Project Logs
Collapse
  • Small Batch Assembly
    Dave's Dev Lab • 02/06/2019 at 01:07 • 0 comments
    Today I ran a small batch of 6 panels with 30 boards per panel. Solder paste was applied using a stainless steel stencil from OSH Stencils, then the panels were placed into the desktop pick and place machine. After doing a reflow in my AS-5001 from SMTmax,  a quick quality inspection is needed. Once all the boards are confirmed as good, they are ready to be packaged for sale on Dave's Dev Lab Tindie Store.
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Ted Yapo wrote 01/24/2019 at 03:29 • point
When I first saw this project, I thought you had paralleled two of them for even lower noise!
Dave's Dev Lab wrote 01/24/2019 at 03:31 • point
hehe, ultra-ultra low noise!
TinySys aims to be an entry point into building a fully custom FPGA board. It's currently expands a core FPGA board for development purposes
Project Owner Contributor
TinySys - A RISC-V based system on FPGA
engin-cilasunEngin Cilasun
Low Cost STEAM Board (LoCoS) to give access to STEAM & Technology Education in rural areas in Guatemala.
LoCoS
orodasorodas
World's Smallest RP2040 Development Board
RPDot
william-herrWilliam Herr
This is a spooky and fun learn-to-solder kit!
Spooky Coffin
alpenglow-industriesAlpenglow Industries
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Low Noise Op Amp Breakout Board", please tell us the reason.
Send message
Remove Member
