Ordering some parts
A project log for A Seven Segment Art Installation
A modular board hosting 9 seven-segment displays that can be daisy chained to make an art installation
arduino-enigmaArduino Enigma 03/06/2019 at 00:490 Comments
Just ordered some components from US suppliers, so they should get here fast:
10 x 3Pin 10cm Servo Extension Lead Wire for Futaba RC Connector Cable LB
10Pcs 2.54mm Pitch 0.1 1x15 15 Pin 15p Female Dupont Header Arduino Nano Headers
And then when those two arrive and everything is put together, then the spacers can be selected:
25/100pcs Black Plastic Nylon M2 M3 M4 Hex Column Standoff Spacer Phillips Screw
