The tile board can now control 16 digits using only an Arduino Nano
A project log for A Seven Segment Art Installation
A modular board hosting 9 seven-segment displays that can be daisy chained to make an art installation
arduino-enigmaArduino Enigma 08/16/2020 at 17:360 Comments
Here is a picture of the new 16 digit board using the Common Anode (CA) in parallel with Common Cathode (CC) technique.
Here is a schematic for a 4 digit board using only 10 IO pins. Each additional pair of digits will only cost 1 pin.
Read more about it at:
https://arduinoenigma.blogspot.com/2020/08/7-segment-led-board-now-drives-16-leds.html
